soft pedal with ls1 swap?
Old Jul 22, 2012 | 01:25 PM
lowbird's Avatar
Car: 88 firebird
Engine: 350tpi
Axle/Gears: 373
Did the ls1 swap the other day with all new parts . The car does stop so much better but the pedal is a lot softer then before . I'm not sure if this normal or something wrong. It has more travel now also
Old Aug 3, 2012 | 04:41 PM
87350IROC's Avatar
Car: 87' IROC
Re: soft pedal with ls1 swap?
That will happen with those components.
I calculated the pedal should be 13% softer and 16% shorter compared to stock, for the same deceleration rate.
Right click - view image for larger
customblackbird
Aug 15, 2021 10:16 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
