Brake issues after Upgrade
Old Jul 30, 2012 | 05:44 PM
1986lt1boy's Avatar
Car: 1986 Trans AM
Engine: 396 LT1 Stroker
Axle/Gears: Ford 9 Inch w/ 3:70 Gears
Hello all, I recently Upgraded the rear brakes in my 86 Trans am from Drums to Disc's. I Installed a Pair of Wilwood Dynalite Pro Series Disc Brakes. I upgraded to a Stock GM Disc Brake Prop Valve, Wilwood Master Cylinder, Stainless Steel Brake lines all around and Steel Braided Flex Lines going to the Caliper.
Here my Problem, When I Have to Stop Slowly (say stopping at a stop sign) the brakes respond well. But when I have to stop fast (say a panic stop) Or when heavy pressure is applied the car stops horrible. It almost feels like I have half a pedal or like there is something preventing the pedal from being pressed down. The car doesnt want to stop. My old Drum Brakes worked better than these. The wheels dont lock up either when the pedal is pressed hard and fast.
Any help would be great as I try to figure this one out.
The Front Brakes are all stock.
Old Jul 31, 2012 | 04:05 PM
87350IROC's Avatar
Car: 87' IROC
Re: Brake issues after Upgrade
Post a link to the brake kit and the master cylinder.
Old Aug 1, 2012 | 06:14 PM
1986lt1boy's Avatar
Car: 1986 Trans AM
Here are 2 Links
Brake Kit
http://www.summitracing.com/parts/WIL-140-7582-D/
Master
http://www.shop.speedunlimited.com/p...-112-bore.aspx
I am running a Currie ford 9 inch in my Car.
Old Aug 2, 2012 | 10:29 AM
87350IROC's Avatar
Car: 87' IROC
Originally Posted by 1986lt1boy
Here are 2 Links
Brake Kit
Master
So the front are the same? Does it seem like the fronts aren't working as well either?
Did you bench bleed the master cylinder?
Which GM disc/disc prop vavle did you use? there are at least two different ones.
Old Aug 7, 2012 | 06:49 PM
1986lt1boy's Avatar
Car: 1986 Trans AM
The Fronts are stock. No they dont seem to work well either the car as a whole doesnt want to stop.
Yes I bench bled the master.
I cant find the receipt for the Prop. The Numbers I pulled off it are listed below.
10994900 ACH K/H - Off the Black rubber Cap on the Front of the Prop.
NB 14 KH 1479 or 1473 - Stamped number off the LT Side of the Prop
502525757- Engraved number off the LT side of the Prop (Hard to see this one)
Old Aug 8, 2012 | 07:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
By going to the larger bore Wilwood M/C (1.2") you decreased the line pressure by approximately 38%. This is why the brakes no longer work as they should.
Need to get a M/C with a bore of about 24 mm to be the same as the brakes originally were.
RBob.
Old Aug 13, 2012 | 06:23 PM
1986lt1boy's Avatar
Car: 1986 Trans AM
Thanks for the input Rob. Is there anyway I could modify mine or do I have to replace the entire Master? Also I think the bore size is only 1.120.
Old Aug 13, 2012 | 07:28 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I would just put on a stock master cylinder and see how it responds.
Old Aug 13, 2012 | 08:08 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, 1.120", not 1.2", too early for me to be posting. However, that is still a 29% reduction in line pressure.
The other item is what brakes pads did you use? Although, it appears that you only changed the rear brakes, lines, combo valve, and the M/C. So the front pads are the same as before? If so, we are back to the reduction in line pressure.
Or the combo valve is bad. The best way to troubleshoot this is to get a brake caliper pressure gauge.
If you still have the stock M/C, bolt it on and see what happens.
RBob.
Frozer!!!
Jan 19, 2024 04:55 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
