1LE Brake Lines
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
1LE Brake Lines
Is it possible to use the factory lines? I replaced them about 3 years ago with GM replacements so I'd like to keep them if at all possible.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 1LE Brake Lines
What are you asking? 1le lines are factory lines. You will not find NOS ones, but you can still get them elsewhere by various brands. I bought some acdelco ones about a year back and they should still be available.
You can't use the lines from the base/standard brakes on the 1le, they are shorter
Engine: 355 TPI
Re: 1LE Brake Lines
I've been looking with the part number I have and I can't find them anywhere. Can you point me in the right direction?
Engine: 355 TPI
Re: 1LE Brake Lines
I determined that the 1LE brake hose length is 21 1/4 inches. ACDelco part number is 18J618.
