PBR caliper position?
Old Feb 10, 2013 | 11:20 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I'm putting PBR disk brakes on a 9-bolt from an '86 TA. The pictures I've seen show the calipers behind and low on the axle. However, when I try that the bleed screw is below the banjo bolt. The parts are all marked L and R so the only way it looks like they should go on is in front of the axle and above the center line. Is this right? Did PBR brakes get put in different positions?
Old Feb 10, 2013 | 12:46 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: PBR caliper position?
Unless the R goes on the driver side and L on the passenger???
Old Feb 10, 2013 | 12:57 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No. Both to the back side. Pics in the following link might be helpful:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Feb 10, 2013 | 01:18 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
So for that to work the parts stamped "R" need to go n the driver's side. I assumed at first they would go on the passenger side. Thanks.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
the_hamturdler
Sep 30, 2015 12:50 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
