SSBC Adjustable Proportion Valve
Old Apr 11, 2013 | 07:27 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Thinking of picking up an adjustable proportioning valve, this is the one I am thinking about:
http://ssbrakes.com/i-10094012-distr...ble-black.html
I can't seem to find any serious reviews on it and there are no comments here.
Anyone tried this one or have another recommendation?
Old Apr 11, 2013 | 07:42 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: SSBC Adjustable Proportion Valve
Holy expensive piece of equipment Batman!! I got the Summit one for about 40$ shipped and it works great.
Old Apr 11, 2013 | 07:45 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Image attached? Now?
Attached Thumbnails SSBC Adjustable Proportion Valve-propvalve-1.jpg   SSBC Adjustable Proportion Valve-propvalve-2.jpg
Old Apr 11, 2013 | 07:53 PM
nosajwols's Avatar
Car: 82 Z28
The street price is under 100, they show list. This one is also the distribution block and has the brake switch as well. So it entirely replaces the factory one, this is what I am after.
The summit one that does the above is actually $10 more than this one on their site (and looks like a clone....).
Old Apr 11, 2013 | 07:56 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
All true. You only mentioned the proportioning valve. Fine if you want to replace the whole block.
Old Apr 12, 2013 | 08:43 AM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
Axle/Gears: 3.42 Posi
They are good blocks but not needed. All that is needed is a direct line to the front brakes, and put a proporting valve, just a simple Wilwood like the one shown, and they are around $40
I do like the warning lights for the brakes but that's what brake bias gauges are for!
Good luck, you cannot go wrong with SSBC Proportioning block.
Old Apr 14, 2013 | 06:04 PM
nickyakker's Avatar
Car: 1982 Firebird T/A
So why did you get the summit brand when the single **** style ssbc valve is 6 dollars more and smaller????
Old Apr 14, 2013 | 06:19 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
@nickyakker
I have the Wilwood for my car. Wilwood is contracted by Summit to make their 'Summit' brand. The SSBC, on the other hand I never looked at. The only SSBC that I looked at getting for my car was the same one as the OP.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
