4th gen front braided brake lines
Old Apr 15, 2013 | 11:18 PM
Nefarious's Avatar
Car: 1991 Camaro RS convert
Engine: 5.0L TBI
Axle/Gears: 4th gen axle/4.11 gears
After researching extensively on the subject I came to the conclusion that for 98-02 4th gen brakes I can use front 3rd gen lines and for the 98-02 rear I require the 4th gen kit. I haven't seen anyone mention the use of front 4th gen braided lines. I'm waiting on a response from Kore3 but in the mean time I wanted to just ask the question on this kit 692280 from russell and how will the front lines do?
Old Apr 24, 2013 | 11:29 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Axle/Gears: 4gen 3.23 PBR
Re: 4th gen front braided brake lines
Looking for the same answer. I want to upgrade to braided lines my ls1 fronts and rear lt1 pbr. Would like to buy as a kit all lines if there is one.
Old Apr 25, 2013 | 12:03 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
For the rear you am just buy 4th gen braided lines and it will will work with your hard lines to caliper
Well it worked for me but I'm running LS1 rear brake
The thread sizes is the same I believe
Old Apr 25, 2013 | 08:21 AM
Nefarious's Avatar
Engine: 5.0L TBI
For your lines did you buy a whole braided line kit together? Do you remember which kit it was? How is fitment at the caliper on the LS1 front brake lines? Unfortunately Kore3 doesn't produce the center rear drop line with the T-fitting so I need to find out if this kit will work or order from flynbye.
Old Apr 30, 2013 | 01:04 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
The front lines were given to me by a good friend... As for the rear i got them from a shop that sells brake components...
I just asked for 02 camaro brake lines and they fit perfect
as for the other line that goes to the t fitting im still looking for that line
Old Apr 30, 2013 | 01:07 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Im running Baer brakes in the front and ls1 in tge rear
as for the lines check out brakenetic in long beach ca... Thats where i got my lines from
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
