Proportion/combo, valve difference questions
Old Jun 14, 2013 | 11:55 AM
rwerk91's Avatar
Car: 91 Camaro
Engine: LS1, LSXRT &102mm TB, Cam,225 Heads
Axle/Gears: 9" 4.10 w/31 spline axles
Ok switching over from drum to pbr disc in the rear. Guy before me adjusted brakes somehow so for some reason brakes almost all in the front. What or how would he have done this? Second is there a difference between combo valve for rear cast calipers over pbrs?Third, Can I Visually tell if a combo valve is disc/disc or disc/drum?Fourth I have a 92 z28 disc/disc valve I can pull or I have a 86 WS6 should be Disc/disc valve laying around, is one better than the other or are they the same rather just use the WS6 one cause its its already out but if the Zs better Id like to know
Old Jun 14, 2013 | 12:43 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Proportion/combo, valve difference questions
Check the 10-bolt FAQ for brake info.
JamesC
Old Jun 14, 2013 | 01:08 PM
rwerk91's Avatar
Car: 91 Camaro
Yeah checked that. Gave some really good info. Didnt touch on everything I was curious about. Just gonna call it safe and pull the z28 s.
Old Jun 14, 2013 | 03:03 PM
JamesC's Avatar
Originally Posted by rwerk91
...is there a difference between combo valve for rear cast calipers over pbrs?
I have a 92 z28 disc/disc valve I can pull or I have a 86 WS6 should be Disc/disc valve laying around, is one better than the other....
For best braking results, I'd advise using the valve designed for a particular system: disc/drum, disc/standard disc, or disc/PBR.
No.
The tube nut threads changed in late 89, IIRC, so the valve from the 86 shouldn't fit your 91--and wouldn't be the best choice anyway. The 92 valve should be perfect.
Of course, you could always go the adjustable route.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
fasteddi
Sep 2, 2015 10:29 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
