quick brake help rear disk aluminum
Old Sep 7, 2013 | 09:39 PM
mreld3r's Avatar
Car: 1986 Iroc, 89RS
Engine: 350 tpi, 350 tbi
Transmission: 700r4,700r4
Axle/Gears: 4.10,2.73
While I was at the pick-n-pull; I found a '92 camaro with aluminum disks on the rear. Quick check of the RPO found that the car was originally disk/drum.
I recognized the brakes as PBR; so I removed them. Pulled the rear cover and found 3.42 posi and something that appeared to be a bicycle sprocket thing. Electrical connector on top of the third member. LT1 swap,,correct??
There are NO emergency brake cables installed at all.
Question: The left side of the caliper (only) has some sort of (large metal thing, and a heavy duty spring on what appears to be part of the parking brake assy...some sort of damper??)
Is the passenger-side supposed to have the spring/damper assy; also?
I will return monday to remove the complete third member for "my" car.
If the spring/damper assy. is missing from the right side, where could I purchase one..
Does anyone have a diagram/parts breakdown of this brake assy; so I know what parts i need and how they go together?
Thank you
mike
Old Sep 8, 2013 | 12:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: quick brake help rear disk aluminum
The dampers aren't necessary (many 89-92 cars weren't equipped with them from the factory). I'd ditch them altogether.
JamesC
Old Sep 8, 2013 | 06:55 AM
JamesC's Avatar
I neglected to mention that the spring is part of the parking brake. Pics in the following link:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
IIRC, the springs and cables can be found below:
http://www.flynbye.com/
JamesC
Old Sep 8, 2013 | 07:24 AM
mreld3r's Avatar
So; I am missing parts.
Here is what I have.
Old Sep 8, 2013 | 07:32 AM
mreld3r's Avatar
It appears that I am missing a spring, a bracket, and a ton of dirt removal.
This would also explain why the right rear rotor was completely shot.
Without that spring/bracket the parking brake was dragging on the rotor.
Thank you very much james
Sincerely
mike
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
z28addict8490
Aug 7, 2015 08:48 PM
