new caliper thread size
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
I have new brakes that take a 10mm x 1.5 banjo fitting in the caliper.
My old brakes are disc and probably from a 89. what size fittings were the stock lines?
And is there a conversion fitting avail?
Car: 1987 GTA
Re: new caliper thread size
oh maybe I have the terminology wrong. is there a brake line adapter?
what size fitting is the stock caliper brake line fitting
No adapter needed.
All you need is a banjo bolt to match the hole in your caliper.
You can pick up any size of those bolts you want at parts stores. No problem, you'll have it handled in a coupla seconds from now.
toronto formula
Nov 10, 2015 06:17 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
