Rear caliper mounting brackets
Car: 1991 Firebird "Melba Toast"
Axle/Gears: 31 spline moser/3.70 gears
I'm buying a ford 9" rear end for my firebird, and the manufacturers only option to fit this housing for f body disc breaks is 93-02. I can get calipers, discs, pads, lines but no parts store nor gm dealers can order the mounting brackets. Any clues, besides rummaging through salvage yard, on where I can find a set?
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Rear caliper mounting brackets
this site has a classified ad section.i bought mine off craigslist.theres always someone parting out a forth gen.btw i believe the 93-97s use the same rear brakes as the 89-92.
Engine: 4++,350 & 305 CIs
89-97 are almost the same, some small changes but they pretty much all interchange.
I did this back in the early 90s, not hard at all. Good luck with your swap.
TTop, this isn't a break question but since you've already done a 9" rear end swap, what's difference in 28 & 31 spline axels? I'm gonna be mostly street, and the strip just once in awhile.
If you can get the 31 spline, I don't think there is a cost difference so a little extra strength with the 31s are good.
I ordered a Ford 9 inch 31 spline rear end today, can't wait to get it installed.
I've had to do a lot of searching online and also calling auto parts stores and GM dealers for the information I needed. So I figured I would list a few parts that I've gotten, in case someone else with a third GEN is wanting to upgrade their car. Hopefully this will save them some time on gathering info if they come across this threat.
Ford 9" rear end housing and axles http://www.quickperformance.com/QP-G...xles_p_40.html
Ford 9" inch third member (you need to send a message to this eBay seller and let him know what vehicle this is going on so he can install the correct yoke for your application) http://m.ebay.com/itm/151246978645?nav=VI
Rear caliper mounting brackets for 93-02 F body disc breaks http://m.ebay.com/itm/231091413647
93 Trans Am calipers, pads, rotors, rubber brake lines- O'Reilly's auto-parts (I always use O'Reilly but I'm sure you can get these items at any parts store)
Now I'm not sure about the metal brake lines but if it comes down to it and I need to get some bent, here's who I will use: Right Stuff http://www.getdiscbrakes.com
I need to double check my measurements but if everything is right like I think it is, here's the wheels and tires I will be ordering: http://m.summitracing.com/parts/wld-791b-510284
http://m.summitracing.com/parts/mtt-3755r
Traction bars http://www.summitracing.com/parts/la...w/make/pontiac
Shocks http://www.summitracing.com/parts/la...w/make/pontiac
Sub frame connectors (make sure that if you are going to be running headers that you order these connectors because the connectors for a stock engine application will not fit). http://m.summitracing.com/parts/BMR-SFC008H
Transmission http://performabuilt.com/level-2.html
That's it for now, I will add more details as I move further in my project
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
check out Inlinetube.com they are local here is Michigan but they have a huge product line and its where I bought my stainless brake lines.
I also have a full ls1 front and rear brake setup for sale, I have the rear backing plates as well, they aren't perfectly new. PM if your wanting to buy the backing plates. I can get some pics for you
thanks for the info on that break line Co.
1992 Trans Am
May 10, 2023 07:19 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
