Rear disc conversion question
Car: Red 86 Iroc-z / Black 90 Iroc-z
Engine: Mild 350 / Vortec L31
Transmission: TH700R4 / TH700R4
Axle/Gears: 3.42 / 2.73
Hi !
I have to camaro's, one has drums and the other has discs. I am taking the whole rear end from one to convert the other to disc. What else is differant, do i need to swap the proportional valves ?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear disc conversion question
Here's primer that should answer many of your questions:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
I am taking the whole disc rear end with the housing. Are the valves the same ??
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Ok so i swapped in the whole disc rear end, left the stock drum valve and every thing seems fine after a good test drive !
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Correct being one from a disc car, not necessarily aftermarket right?
I ask because I have a 4th gen disc rear going in my 83 'bird and need to know myself!
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
