E-Brake cable issue!
Old Jun 3, 2014 | 12:01 AM
bttrflybird's Avatar
Car: 89' Bandit 2 #104 of 500
Engine: LS1 5.7L
Transmission: 4L60e
Axle/Gears: 3.23 posi
I got rear disk brake swap and i dont have the ebrake connected. Problem is it now dangles on top of the rotating drive shaft not weight bearing but scratching.
Is there a way to remove the ebrake cable from within the car?
Old Jun 3, 2014 | 11:59 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Re: E-Brake cable issue!
Remove the console, and underneath there follow the ebrake cable connected to the handle until you find (probably under the carpet) the cable leads to a somwehat big rubber plug (if it's still intact). Remove the plug and pull the cable through.,
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
greenyone
Sep 2, 2015 03:39 PM
