Brakes are weak. Master cylinder? Help!!
Old Jul 6, 2014 | 11:02 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
The brakes on my 87 trans am gta are weak. By weak I mean I have to push all the way to the floor for the car to stop, and still doesn't stop right away. Just bearly! Help!!!
Old Jul 7, 2014 | 04:26 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: Brakes are weak. Master cylinder? Help!!
How's the fluid level in your brake fluid reservoir?
Sounds to me like you've got a lot of air in your brake lines.
Do you have to apply a LOT of force to the pedal or does it go down quite easily?
Old Jul 7, 2014 | 10:04 PM
Engine: 5.7 350 TPI
It goes down about 2 inches and then gets hard I believe it's the master cylinder
Old Jul 8, 2014 | 01:25 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
May still be air, which has to come from somewhere, so yes, the MC may have a defect. Only one way to rule that out: take it apart and look inside
Perhaps the seals have corroded.
Old Jul 8, 2014 | 07:05 PM
Engine: 5.7 350 TPI
Thanks for the help really appreciate it
Old Jul 9, 2014 | 07:21 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Sure. You're welcome. Keep us posted, please!
Old Jul 23, 2014 | 09:22 PM
topj's Avatar
Car: 88 Camaro IROCZ Convertible
Engine: 305 tbi
Transmission: auto
i think i may be having this same problem not sure... i hear like a vacuum noise coming from the brake pedal area and i have to push the pedal down all the way and it wasnt like this before...can burn outs cause this?
Old Jul 23, 2014 | 09:52 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Bad brake booster if you hear hissing noise. Swapped mine out, now it's fine.
Old Sep 7, 2014 | 10:24 AM
Engine: 5.7 350 TPI
It has all the symptoms of a bad brake booster but it holds vacuum so I ruled that out. Now the master is left. Can the master cause a hard pedal after about 2 inches. And the brakes are weak too can't lock the wheels. I ruled air in the lines out because if it had air in lines then the pedal would go to the floor. What can it be. Mind you that I took the proportioning valve out and put a Wilwood one on the rear brakes because I though that was the problem in the first place but still is that same thing
db057
Apr 28, 2019 07:45 AM
dbrochard
Oct 3, 2015 12:43 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
