88 gta brake fluid leaks from e brake bolt on cast iron disc brake calipers
Just as title says brake fluid leaks out e brake adjuster bolt on cast iron disc brake calipers and no fluid comes out bleeder valve. Can't figure out any help be great
Re: 88 gta brake fluid leaks from e brake bolt on cast iron disc brake calipers
I had the pre 88 rear disc brakes and im gonna say this they suck a** best to do a 89+ rear end or change the backing plates to do the 89 pbr brakes the e brake will actually work and u will feel better braking coming from the rear when stopping
@1BAD84Z28 did you sort this out? My 87 GTA has the same leak from the e-brake actuator. Where's the problem With this style caliper, is it invisible inside the caliper or is it the lever seal that fails?
Could be either, and during the adjustment seeing a small leak is normal. So, the caliper does rely on the external seal to prevent leaking during operation.
You should be able to replace the leaver seals pretty easy to see if it still leaks. Your parking brake cables probably need lubricated anyway. So loosen them up at the equalizer above the driveshaft, drop them off the calipers, remove your leavers, and put new seals on. Lubricate all the slide points of the cables and the cable themselves and put it all back together and see if you still have the leak. Careful while working with the actuators. You don't want them to move and lose your adjustment.
I never had a pre-88 Parking brake fail to work. You have to use it frequently to keep it in adjustment. Easiest way is to just use it every time you park. As far as braking goes, this goes back into having them properly adjusted and using them to keep them adjusted. The rear brakes on these cars were not designed to do a lot of braking, but that can be remedied by a $5.00 spring.
What I did have on my 86 way back when. was the passenger side caliper that would not stop leaking. Went through about 9 or 10 (No lie) Autozone reman units until one held up. They were fine when installed, but non ever made it out of the warranty period before they would blow a seal.
