fittings??
Old Jan 1, 2015 | 07:54 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
fittings??
Ok so i am doing a manual master conversion
Looks like 6mm line i need to adapt to the perportion valve that is 3/8. I can get a 1/4 to 3/8 fitting
Can i use the 1/4 fitting on a 6mm line??
Old Jan 3, 2015 | 07:33 AM
Re: fittings??
Depends on your tools:
If your flare tool will grip the line, then yes.
Old Jan 3, 2015 | 11:28 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: fittings??
1/4 fittings will work on 6mm line. 6mm fittings need to be drilled out to work on 1/4 line
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
