rear brake line ends
Old May 16, 2015 | 09:17 PM
03_z's Avatar
Car: 84 z28
Engine: 406ci
Transmission: th350
I am replacing the steel brake line from the prop valve to the rear end on my 84 camaro. The car has an aluminum prop valve. The thread pitch is different on each end. Could anyone tell me what size line I need and what the thread pitch is on each end? I tried a search but have been unsuccessful. Thanks.
Old May 17, 2015 | 01:56 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: rear brake line ends
IIRC '84 swap the change over year from SAE to metric so it could be SAE or metric fittings.
The rear line fittings into wheel cylinder will be 3/8-24 OR M10x1
If it's rear disk, then fitting to the rear caliper will be M10x1.5
The rubber line in rear that connects steel line on car to steel lines across rear axle housing will have thread sizes of 2) M10x1 junction, M12x1 female
Front calipers takes a M10x1.5 fitting
Master cylinder fittings are Primary M11x1.5 , Secondary M12x1.0
I can not find the prop valve sizes, sorry
Old May 17, 2015 | 09:56 AM
03_z's Avatar
Car: 84 z28
Engine: 406ci
Transmission: th350
I am pretty sure the prop valve has metric fittings. Thanks for the reply with all the fitting sizes. Very helpful and informative.
Old May 17, 2015 | 10:58 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
just save and reuse the old fittings from your old lines in the same places.
Old May 17, 2015 | 08:44 PM
03_z's Avatar
Car: 84 z28
Engine: 406ci
Transmission: th350
This is probably what I will do. I will need to buy another flaring tool to make bubble flares. Thanks.
Old May 19, 2015 | 01:37 AM
Car: 1988 Camaro
Your welcome
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
