Brakes That Fit 16" GTA Wheels
Old Jun 11, 2015 | 11:03 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
I'm likely going with a kit from one of the popular places, but has anyone done a 12" ls1 rotor/Z06 Caliper combo with the 16" GTA crosslace wheels? Probably needs a spacer, but how big?
Old Jun 12, 2015 | 02:44 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Brakes That Fit 16" GTA Wheels
i am running LS1 brakes all around, and only needed a thin spacer (i made it out of 3/16" steel) on the fronts to run the GTA's... i don't know about using Vette calipers, but i do know that the Camaro LS1 calipers haul the car down from speed pretty effectively..
Old Apr 8, 2020 | 07:44 PM
Anton28's Avatar
Deleted*
Old Apr 9, 2020 | 12:18 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
If you mean C6 Z06 calipers, then no, they won't work with 12" rotors. A 12" rotor barely reaches halfway up the pistons. Those calipers are designed for 14" front rotors. I believe Ed Miller offers a bracket that's supposed to allow those calipers to work with 13.4" Z51 front rotors, but even that appears suspect that the top of the pad might fit higher than the top of the rotor. There might be some 12" 6thgen Camaro options. Not sure if they'd fit 16" wheels, but Scott at Big Brake Upgrade would probably know.
Last edited by LAFireboyd; Apr 9, 2020 at 09:09 AM. Reason: Originally stated C7, but meant 6thgen. Corrected.
Old Jun 19, 2020 | 02:41 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
12" 6thgen Camaro options have electric ebrakes on rear calipers?
Are they compatibles with 82-88 3gen rear disc brakes?Someone knows?
Thanks,
Anton28
Brakes
18
Jul 7, 2022 11:54 PM
91banditt2
Brakes
Jul 11, 2011 09:23 PM
nape
Nov 19, 2005 12:05 AM
flyitlikustolit
Brakes
Mar 15, 2005 11:17 PM
N.W. T/A
Brakes
19
Feb 26, 2004 10:44 PM
