Brake line size
Old Jul 17, 2015 | 12:42 AM
mr.anderson's Avatar
Brake line size
Brakes went out on my 89 camaro. Just guna replace everything so I'm wondering what size the brake lines are. Thanks
Old Jul 17, 2015 | 09:17 AM
Re: Brake line size
Varies from car to car and system to system (drums vs disc for example) There's acoupla common sizes. Most are 6mm. Several different nut sizes as well.
Brake lines don't often "go out", except for rusting through, in which case there's usually obvious evidence of a leak. Replacing them tends to be ALOT of trouble with no payoff.
Old Jul 17, 2015 | 12:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Brake line size
The line front to rear is 6mm. The rest are 4.75 mm.
if you are going to replace them it would be worth you time to order replacement prevent lines and all new flex lines as well.
Old Jul 17, 2015 | 04:32 PM
Re: Brake line size
Awesome thanks.
Reddeath210
Oct 6, 2015 08:20 AM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
