PBR'S worth the upgrade?
Old Nov 16, 2015 | 09:46 AM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Hello all, I have the chance to upgrade my factory iron delco moraine calipers to PBR's just wondering if it is really worth the upgrade or not and if so is the prop valve somehow different then the one I already have since my car is already a 4 wheel disc car?
Old Nov 16, 2015 | 10:18 AM
Twin_Turbo's Avatar
Re: PBR'S worth the upgrade?
Yes, def worth it. No more parking brake issues, calipers that actually work.
Old Nov 16, 2015 | 03:34 PM
J. Chris Davis's Avatar
I converted to them on my second gen and they work great. Will be doing it to the IROC in the next year or two. Shouldn't need to change the prop valve since it is already 4 wheel disc.
Old Nov 16, 2015 | 09:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There are different valves for different applications: Disc/drum, disc/disc (Delco-Moraine) and disc/disc (PBR). Personally, I'd use the one designed for my braking system.
You might check the following FAQ for more info about combination valves, master cylinders and parking brake cables:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Nov 17, 2015 | 11:35 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Absolutely worth it. Even better put in an adjustable prop valve as well so you can crank up the rear braking even more to get the most out of it. Made a significant difference for me.
Old Nov 19, 2015 | 09:29 AM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Change 'em, 4 wheel disc is a misnomer with the delco iron rear calipers....more like 2 wheel disc brakes.
69GTOby
Jul 19, 2017 12:33 AM
BrianI
Car Audio
Feb 21, 2016 12:26 PM
Thornburg
Nov 4, 2015 08:53 PM
Damon
Oct 25, 2015 08:20 PM
bamaboy0323
Wheels and Tires
Oct 22, 2015 08:43 AM
