Bypass stock prop valve?
Old Nov 30, 2015 | 06:51 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Just feeling out an idea I had (I'm sure someone else has thought of it before but I didn't see anything).
So my rear brakes were converted to disks, and they just don't stop as well as they should. Tried the stiffer spring, and it helped, but still did not get it to where it should be. I'd like to keep the stock look with the old combination valve and a functioning pressure switch. Would it be possible to disable the prop valve for the rear somehow, then put one of the small adjustable prop valves downstream in the rear brake line? I'm not exactly sure how I'd disable the prop valve, maybe just sealing the hole in the cap and sealing the threads somehow with removing the little plunger would do it, or perhaps installing a rigid piece of pipe in place of the spring...
So is this idea sane? Would certainly be a lot less work to keep all the lines intact and cut/flare the rear line after the combination valve than it would be to replace the combination valve entirely.
Old Nov 30, 2015 | 07:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Bypass stock prop valve?
Why not buy the proper prop valve for a disc/disc car?
Old Nov 30, 2015 | 08:02 PM
someone972's Avatar
Engine: 5.7L TPI
Because they are exceedingly expensive/difficult to find at this point. If you know a source for them I'd be happy to hear it .
Old Dec 1, 2015 | 12:14 AM
Night rider327's Avatar
Car: 1988 Camaro
I have 2 used ones for sale. Both from disk brake rear cars
$60 each, shipped. If you are interested PM me
Old Dec 1, 2015 | 03:20 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
when i put the '02 disc rear end in my car, i took the spring out of mine and screwed the cap back on.. then i added an adjustable valve in the rear line to dial it in. now that all 4 corners have the "LS1" brakes and the valve is dialed in, it stops on a dime..
Old Dec 1, 2015 | 07:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Take note that the only OE valve that will fit your 91 is the second-design 1LE valve. More info in the 10-Bolt FAQ.
JamesC
69GTOby
Jul 19, 2017 12:33 AM
Cadaver Puncher
Nov 5, 2015 05:02 PM
smnichol86
Brakes
Nov 5, 2015 02:50 PM
perZ
Nov 3, 2015 02:11 PM
n8lesher
Nov 1, 2015 06:19 PM
