C7 Brakes on 3rd Gen, It Is Possible???
Old Apr 21, 2016 | 06:47 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Just as the title says and assuming larger wheels are in the recipe, what else would it be needed for C7 calipers and rotors to be fitted into 3rd gens???
Old Apr 21, 2016 | 07:18 AM
87v6Bird's Avatar
Car: 87 Firebird, 89 Trans Am
Engine: 406, LB9
Transmission: T56, 700R4
Axle/Gears: 3.23 Torsen, 2.73 Posi
Re: C7 Brakes on 3rd Gen, It Is Possible???
Here are my thread and another member's thread on swapping the base C7 calipers. As with all swaps you need modified spindles and caliper brackets to make it work. When I did the swap you needed to either shim the standard hubs or run 1LE hubs in order to get the correct caliper/rotor alignment. Check out http://bigbrakeupgrade.com/C7.htm for more info. Scott was great to work with.
https://www.thirdgen.org/forums/brak...s-c7-base.html
https://www.thirdgen.org/forums/brak...ette-base.html
Old Apr 21, 2016 | 01:19 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
make the stock rotors into hubs, cut off the stock caliper mounting ears, tap the dust shield mounting holes to a bigger size, and make simple brackets to bolt the calipers to the spindles..
easy..
Old Apr 21, 2016 | 06:14 PM
BBU.COM's Avatar
Top Answer: 1
Yes, Base brakes, Z51 or Z06 I can help if you want.
Z51 w/ slotted and drilled (13.3 4 piston)
15` Z06 with two piece OE rotor (14.6 / 6 piston)
Base JL9 (12.6 rotor with 4 piston caliper)
Z51/JL9 Rears (13.3 4 piston) with park brake
Old Apr 21, 2016 | 06:44 PM
BOTTLEDZ28's Avatar
Transmission: A4
If you are going to go with a brake upgrade then I highly suggest you go through Scott at bigbrakeupgrade.com.
He set me up with C6 Z51 front brakes and I couldn't be happier.
Brad
Old Jul 27, 2023 | 01:29 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
i have a 92 trans am wanting to upgrade, I have z51/jl9 front and rear calipers and rotors what else do i need
Old Jul 27, 2023 | 02:07 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Modified spindal, and caliper bracket. Contact Scott at Big Brake Upgrade.
90Camaro5speed
Brakes
Mar 29, 2016 11:49 PM
Slash
Wheels and Tires
Mar 23, 2016 09:36 PM
Abubaca
Nov 28, 2001 02:36 AM
Phil87IROC
Mar 24, 2001 06:49 PM
