line lock
Old May 12, 2016 | 08:25 AM
s19243h's Avatar
line lock
just wondering how you guys run the brake lines on your line locks ,i had mine going from the m/c to the line lock solenoid from the selonoid to the proportioning valve and the cars still rolls when activated, so i am going back to m/c to proportioning valve from valve to solenoid out from selonoid to a T TO BOTH FRONT BRAKE LINES
Old May 12, 2016 | 11:33 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: line lock
Did you pump up and hold your brake before triggering the line lock?
Every one I have used over the years would not hold with out pumping pedal a few times and holding down hard before triggering the line lock
Old May 12, 2016 | 11:49 AM
s19243h's Avatar
Re: line lock
yes i did and still wont hold the front wheels
Old May 19, 2016 | 06:32 AM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Re: line lock
I did away with the factory P-Valve, I have the master cylinder going to the line lock then a "T" and out to both front brakes.
It holds every time with no pumping required.
Here is the thread:
https://www.thirdgen.org/forums/brak...up-thread.html
In the 4th post is a copy of a drawing from another thread that shows what I did. Later there are some pictures of my set up.
turd_gen
Brakes
May 7, 2016 01:28 PM
dpmalibu
Apr 27, 2016 06:23 PM
Hotrodder
Apr 15, 2016 02:50 PM
instaldave
Brakes
Apr 13, 2016 12:46 PM
ken3983
Apr 13, 2016 11:43 AM
