Lt1 10 bolt backing plates the same as third gen pbr backing plates?
Old Jun 24, 2016 | 05:38 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Can't seem to get a solid answer on this. I found some fourth gen lt1 era pbr backing plates for a ten bolt. Are they the same as third gen 10 bolt pbr backing plates? In other words can I use my third gen pbr brakes on fourth gem backing plates?
Old Jun 24, 2016 | 05:53 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Lt1 10 bolt backing plates the same as third gen pbr backing plates?
99.9% sure its a Yes.
Old Jul 26, 2016 | 10:48 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
These are 4th gen LT1 PBR backing plates. I believe the only difference between 3rd and 4th gen is the diameter for the axle tube. 4th gen being larger. In my research for my swap everything I've found says the calipers and carriers are identical or nearly identical.
If your backing plates look like these just with a smaller axle tube diameter then I would say you should be good to go.
Old Jul 26, 2016 | 10:52 AM
TTOP350's Avatar
Axle tubes/bearings/seals are the same size.
The 4th gens went to the cast backing plates to cure some of the issues with the stamped parts. You'll need longer caliper mounting bolts if using the 4thgen plates. Make sure they aren't to long and hit the back of the rotor.
wruiz
Brakes
Jun 27, 2016 03:46 PM
turd_gen
Brakes
May 7, 2016 01:28 PM
P-WHY
Apr 25, 2016 12:57 AM
someone972
Interior Parts Wanted
Apr 22, 2016 11:28 AM
ken3983
Apr 13, 2016 11:43 AM
