rear calipers
Old May 29, 2017 | 08:19 AM
jworks's Avatar
Car: 1987 Trans am GTA
Engine: 5.7 liter
rear calipers
so, I went out to the garage today and saw a puddle of brake fluid under my rear passenger side tire. I see that I can replace with a factory crappy caliper but what's the point? might as well crimp the hose off to stop the leak and be done with it. there has to be something in between dealing with junk and replacing with corvette brakes or bigbrakeupgrade ect. so this leads to the question can i replace thd rear brakes with the same kit as the front? I know I would lose the parking brake what other issues will I run in to?
Old May 29, 2017 | 12:11 PM
Drew's Avatar
Re: rear calipers
Assuming... If you don't want to hunt down 1989 specific PBR caliper brackets and upgrade to 89-97 PBR calipers, and you don't want to buy a conversion part... Your best bet would probably be a pair of remanned calipers.
50% of the issues with the delco rear discs come from age, lack of service, etc. If you start with a good pair of calipers, set them up properly and use the e-brake regularly, they aren't completely terrible. They're just not worth converting to from anything else.
Old May 29, 2017 | 01:33 PM
jworks's Avatar
Engine: 5.7 liter
Re: rear calipers
well I'm perfectly ok with getting remanufactured as long as they're going to work ok, I'm probably only going to drive it a couple hundred miles a year so I'm not sure the parking brake will get used very often. I'll look into the PBR and see if that's a possibility
Old May 29, 2017 | 05:56 PM
jworks's Avatar
Engine: 5.7 liter
Re: rear calipers
something like this??
http://m.ebay.com/itm/89-92-Camaro-T...%257Ciid%253A1
Old May 31, 2017 | 09:22 AM
jworks's Avatar
Engine: 5.7 liter
Re: rear calipers
so there is no way to go from this style caliper (stole the pic off of pepboys website) to something more like the front calipers?
Old Jun 1, 2017 | 01:48 PM
jworks's Avatar
Engine: 5.7 liter
Re: rear calipers
Borg Warner 9 Bolt Rear Disc Conversion Plates
These brackets allow the installation of stock 1LE/LT1 rear discs on factory disc rears and replace the now discontinued backing plates for third gen F bodies. Zinc plated laser cut brackets and Grade 8 installation hardware are included. Requires removal of axles for installation. For use with stock sized 11.6" rear discs.
Item #9BoltBktStock
this is from flynbyes website, if im reading this right it will give me the ability to swap out the current calipers and discs to something more like the front
Old Jun 1, 2017 | 02:36 PM
Drew's Avatar
Re: rear calipers
Those are for bolting 89-97 PBR calipers to the rear, aftermarket copies or replacements for the used plates on ebay.
To the best of my knowledge, no one has adapted the fronts to the rear. It's not terribly practical since plenty of options exist for upgrading the rear brakes.
If you're not interested in investing a few hundred dollars or more into the rear discs, you're still furthest ahead to just get a set of rebuilt stock calipers.
Dig around a bit with the search feature, there are hundreds of threads on the stock brakes, PBRs, and upgrades.
Old Jun 1, 2017 | 04:06 PM
jworks's Avatar
Engine: 5.7 liter
Re: rear calipers
I've read around quite a bit. I just can't seem to find anything about switching out the Delco moraine style calipers to a more modern style caliper. from everything I've read the Delco moraine calipers have a high failure rate due to poor auto adjusting. I have already swapped my front brakes and I've been trying to find an upgrade for the rear that doesn't require a lot of modification. I've also read that a 4th gen rear end or the rear end out of an s10 or blazer will have a larger selection of upgrades without excessive modification and the swap is not to difficult. and I dont mind spending a couple of hundred dollars as you implied. i just .want to be able to keep my wheels and get rid of the faulty calipers.
Old Jun 2, 2017 | 07:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear calipers
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
BTW, I experienced no real issues with the Delco-Moraines.
JamesC
