Canister off of brake booster
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: Canister off of brake booster
I believe it's a one-way valve to prevent vacuum loss inside the booster. It stops the vacuum from bleeding out and back into the engine during low vacuum moments.
The check valve is the plastic piece the hose attaches to on the front of the brake booster. This is just a filter and was not used on all years and all models.
That filter is to help protect the large power brake vacuum diaphragm from gasoline fumes attacking it and shortening its life.
The one-way valve is in the elbow connector at the brake booster.
