9-bolt PBR caliper upgrade
Old May 9, 2018 | 06:44 PM
gheatly's Avatar
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
Can someone please confirm for me that on a PBR caliper rear end BOTH calipers are mounted to the rear of the axle? I can only seem to find pics of conversions for the driver's side.
Old May 9, 2018 | 09:14 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 9-bolt PBR caliper upgrade
Yes.
Pics in the following link may be helpful:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old May 10, 2018 | 07:26 AM
Here is a terrible photo showing the pass side of the PBR system.
Old May 10, 2018 | 08:19 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
One that was for sale on here
Old Jan 25, 2020 | 05:03 PM
Slayze's Avatar
Car: 87 Trans Am
Engine: 355 Carb. Nitrous 100 shot
Transmission: TCI Performance Trans. 350 Turbo
Axle/Gears: Borg & Warner 9 bolt 3.70 gears
I would like to upgrade to the PBR as the crappy stock ones keep leaking on me. What's involved in upgrading to the PBR's? New backing plates I assume? Currently have the staggered caliper older 9 bolt set up.
Old Jan 25, 2020 | 06:42 PM
JamesC's Avatar
9- and 10-bolt braking systems are the same:
JamesC
Old Jan 25, 2020 | 06:52 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Pretty sure he's got the 82-88 Iron calipers as mounted on the pre-89 9-bolt.
P.S.
** 89 9-Bolt Backing plates are side-specific. Notice that the outer "LIP" is facing the pumpkin:
Old Jan 25, 2020 | 08:24 PM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
The 9 Bolt PBR had dust shields? My 10 Bolt doesn't have them, but the calipers have round dampeners on the parking brake mechanism...
Old Jan 25, 2020 | 09:47 PM
TTOP350's Avatar
The 1st half of them did, then the tsb for brake moan with light pedal psi while backing up came out. After that came the bracket redesign, it became thicker with a wrap around lip to stiffen it and lost the shields. Like the 10bolt bracket.
Old Jan 26, 2020 | 03:05 PM
Slayze's Avatar
Car: 87 Trans Am
Yeah unfortunately I have to 82-88 9 bolt iron ones
Dante93GTZ
Brakes
Dec 4, 2012 03:52 PM
Dante93GTZ
Brakes
Mar 19, 2012 06:16 AM
drain89
17
Nov 6, 2008 05:56 AM
MasterEvilAce
Aug 25, 2004 02:32 PM
