84 Rear brakes
Old Sep 7, 2018 | 07:15 PM
Bobrohr81's Avatar
Car: 84 ta recaro
Axle/Gears: 3.90
84 Rear brakes
Hi new here I have an 84 trans am recaro edition it came with factory disc brakes I had to cut up my backing plate to get the calipers off so I could change everything to new and rebuild the rear axle I'm having a heck of a time finding them backing plates they hold the caliper I'm wondering is there any difference between the 84 rear brakes and the 89-92 rears
Old Sep 8, 2018 | 08:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 84 Rear brakes
Welcome to TGO. Your 84, if OE, is equipped with iron Delco-Moraine calipers and smaller rotors than the 89+ which are equipped with alum PBR calipers and larger rotors. The following link should provide useful info/pics:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Sep 8, 2018 | 08:16 AM
Bobrohr81's Avatar
Car: 84 ta recaro
Axle/Gears: 3.90
Re: 84 Rear brakes
They are oem they look exactly like the ones in the first picture I have found the calipers rotors hell even the parking brake cables just not them backing plats I found one set on eBay but there a little sketchy looking and font want to run into the problem problem I have now or want to do a ton of work to them and thanks for the info
Old Sep 8, 2018 | 08:27 AM
JamesC's Avatar
Re: 84 Rear brakes
Many members on TGO upgrade. I suggest you advertise in our site's classifieds. My guess is you'll find a pair pretty quickly.
JamesC
Old Sep 8, 2018 | 08:31 AM
Bobrohr81's Avatar
Car: 84 ta recaro
Axle/Gears: 3.90
Re: 84 Rear brakes
Ok thank you
iroc stangs
Brakes
Mar 30, 2019 09:15 AM
dhirocz
Feb 22, 2004 09:27 AM
MrDude_1
Feb 20, 2004 10:18 PM
chekbaka
Nov 21, 2003 07:14 AM
RedFirebird
Jul 9, 2002 04:48 AM
