bubble flare or double flare for caliper side??
Old Nov 6, 2018 | 04:29 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Im making custom lines for my brake setup. The caliper side seems to be a metric bubble flare? Is that correct? Will a double flare seat and not leak or do I need to buy the tool? Or can I use different hoses and convert it to SAE? Send links to parts please if you suggest something. Thank you. Trying finish up the brake lines this weekend.
Build Thread
https://www.thirdgen.org/forums/memb...-2nd-redo.html
Old Nov 6, 2018 | 05:39 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Re: bubble flare or double flare for caliper side??
Thats correct it’s a bubble flare. You’ll need to get the right flaring tool to make the lines. You might be able to rent one from autozone. A double flare won’t seat, and even if it didn’t leak at first it would eventually fail.
Old Nov 6, 2018 | 07:14 PM
seiplentz's Avatar
Car: 85 Z28
Thank you!! Going to look for the tool now.
Old Nov 7, 2018 | 07:45 AM
Or, spend all of $15 a side and replace the calipers, with ones for 83-back, w SAE flare. Might be cheeeeeeeeper than buying the tools.
Old Nov 7, 2018 | 04:17 PM
seiplentz's Avatar
Car: 85 Z28
Got the flare tool for $22 gotta love amazon. Need to do the rear line too.
Old Nov 7, 2018 | 05:01 PM
And you will still have your old calipers... of course you know what the next thing that will happen is, I know FOR SURE it would be what would happen to me anyway, is that I would buy the tool and bend up the lines and make the hoses and whatever all else, IOW spend the shipload of money on it, and discover I need new calipers ANYWAY after it's too late to return anything...
Old Nov 7, 2018 | 10:08 PM
seiplentz's Avatar
Car: 85 Z28
Lol Always the way. I am converting to full Wilwood brakes. Not right away but during this build. Gotta space it out lol Front brakes are 1k the new 9" rear with wilwood 4 piston calipers is $3500 plus the $2500 for the engine rebuild not including heads and parts i already bought. So for right now Im concentrating on the engine bay parts for the paint work. The rest can be done later.
seiplentz
Mar 10, 2019 09:19 PM
