Rear e brake line too long
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
I have been looking around on here for over an hour and I have not found what I am looking for.
So I have a rear that was In the '85 T/A. I swapped it into the '88 drum car, everything has been okay so far other then the t/a mount was different. So I swap the t/a for the one off the '88. My problem is that the e brake cable on the driver side is too long by about a half inch or so. I've tired the adjustment screw with no luck. By the time it gets where it needs to be the passenger side is too tight and the disc is locked. What am I missing here? Or do I need a different length cable? I figured it would all swap in. Thanks for any help
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear e brake line too long
All the parts I am using are for a rear disc setup.
Sorry for my misunderstanding. Could routing be an issue?
JamesC
JamesC
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
If all the parts are correct ( 85 and 88 Disc brake cables should be the same ) it sounds like you didn't unscrew the E-Brake Parking "equalizer" enough. A real PITA when the driveshaft is installed, but really easy to do when the driveshaft is removed.
Post some pics !
Post some pics !
suchamoneypit
Nov 4, 2017 09:36 PM
Darkshot
Mar 21, 2009 06:19 PM
camaro 22
Oct 24, 2001 07:20 AM
camaro 22
Oct 8, 2001 01:45 AM
