LS1 Caliper bracket....
Old May 15, 2019 | 02:52 PM
Doppelganger's Avatar
Car: 1983 Pontiac Trans Am
Engine: 5.0 but about to upgrade.
Hi all, im about to fit some ls1 front brakes to my 83 TA. Ive found a picture of the bracket to print off to size and use as a template but its setup for american printer paper and not UK A4 printer paper. Does anybody have a picture of the bracket with dimensions as this one doesnt so I can't adjust it to be right.
Thanks in advance.
Old May 15, 2019 | 08:32 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: LS1 Caliper bracket....
This PDF has printer scale lines so you can match up the template...
Old May 16, 2019 | 06:23 AM
Thanks for responding. Thats the picture I currently have. Ive tried printing it off at different scales but nothing quite matches the 6" and 8" scales when I measure the printed picture. I guess i'll have to rely on some good old fashioned Maths and work it out after printing.
Thanks again.
Old May 16, 2019 | 12:03 PM
daferris's Avatar
I also have the autocad DXF drawing at home for version 1 of that bracket. PM me your e-mail so I can e-mail it to you..
The free version of the DXF viewer is at https://download.cnet.com/AutoDWG-DX...-10690622.html
Then you can chose A4 for the paper size to print so it's scaled to the correct dimensions.
Dave
Old May 16, 2019 | 04:13 PM
Excellent, thank you. Pm sent.
Old Sep 3, 2019 | 10:43 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
Quick question, if after printing this pdf the lines measure 6 and 8 inches, it’s to scale?
fireburdluvr85
Brakes
Mar 16, 2013 07:00 AM
Screamin86
Apr 28, 2011 12:44 PM
ThirdGenLS1
Brakes
May 14, 2009 12:29 AM
N.W. T/A
Sep 5, 2003 11:36 PM
