ls1 spindal bracket cad drawing
Old May 11, 2009 | 09:48 AM
ThirdGenLS1's Avatar
Car: 1991 Camaro
does anyone have a cad drawing or something with at least dimensions on it so i can make the bracket to mount the ls1 calipers.
Justin
Old May 11, 2009 | 11:15 PM
wanta427's Avatar
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
Re: ls1 spindal bracket cad drawing
I have a PDF file of an LS1 bracket but can't figure out how to post it . PM me your e-mail and I'll send it to you .
Old May 12, 2009 | 08:19 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Check out the bottom of our Boy Scout page www.masontroop763.com
it is a .DWG drawing. My son made one that has the deminsions he should have it tomarrow so I can post it when I get a chance.
You can open it with a free program from Autocad called DWG TrueView.
We made ours out of 3/8 stock but had to cut it down to 5/16 thick to get the caliper centered on the rotor.
PM me your e-mail and I can send you the drawing if you have issues opening it.
Dave
Old May 13, 2009 | 10:53 AM
Car: 1991 Camaro
sweet thanks a lot, thats basicly what i needed i'm able to grab the dimensions off that drawing. Only thing is do any of these holes need counter bored or such. As well are we positive that it needs to be 5/16" thick to fit correctly.
Just want to make sure becuase i can do this at where i worked my last internship at but its a 40 min drive there and dont want to be driving back and forth making changes.
Lastly if you can tell me if any of the holes need to be counter bored or if they are just through holes i can finally get a drawing with all the correct hole call outs and dimisions you would need to make this part and save it in a .dwg and .pdf file so everyone would have access to this.
I'm a mechanical eng. student right now so i have access to solidworks/autocad on my school laptop.
Thanks again
Justin
Old May 13, 2009 | 02:27 PM
wanta427's Avatar
Car: 1991 Z-28
Here's a pic of the bracket I made . I had to use a countersunk bolt in one location to clear the abutment .
Old May 13, 2009 | 04:50 PM
daferris's Avatar
Justin,
The brackets we may for my sons's '92 and my '88 are 5/16 thick we had 3/8 stock but had to surface grind them to 5/16.
Ours we did not counterbore or countersink the holes the abutment JUST clears a 7/16 grade 8 hex head bolt.
the holes were all 7/16 on the brackets we made...
Dave
Old May 13, 2009 | 06:04 PM
wanta427's Avatar
Car: 1991 Z-28
I tapped mine 1/2" and used grade 8 also but the head must just be a little thicker so I used a counter sunk bolt on the bottom .
Old May 14, 2009 | 12:29 AM
Car: 1991 Camaro
awsome guys, thanks a lot. I'm going to make the brackets on the cnc mill this friday. If everything fits correctly to how i made it i will make a drawing of it with all the dimisions and hole call outs so there is no confusion for others who would like to attempt this.
Justin
gixxer92
Apr 12, 2022 12:09 AM
sreZ28
Oct 22, 2015 08:21 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
jer4251
Sep 27, 2015 09:52 PM
jer4251
Sep 16, 2015 11:29 AM
