Front brake anti rattle spring install?
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Anyone have a picture of how it goes I cant find anything on how it goes??
Re: Front brake anti rattle spring install?
Look at the pads. The pad with the wear indicator should have a flat notch in the backing plate at the top center, and a hole closer to the bottom in the middle. Hook the hooked end of the clip on the backing plate in the flat notch, and push it downward until the tab on the other end snaps into the hole. Crocodile Done-dee.
