Help!!! Caliper piston wont retract.
Old Dec 22, 2019 | 03:43 PM
BradsB4C's Avatar
I have a 1992 B4C/1LE car that has not been driven much in the past 15 years. I am trying to get it back on the road but the passenger front caliper pistons wont retract. Any ideas on how to unstick it or will it require rebuilding the caliper?
Old Dec 22, 2019 | 03:48 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Help!!! Caliper piston wont retract.
What have you tried already?
Since you're here asking, probably be easier for you to just buy remans from the parts store and install them
Old Dec 22, 2019 | 03:52 PM
BradsB4C's Avatar
I pulled the caliper and used a C clamp and a piece of metal to push both pistons in at the same time (equally) Re-installed and it was still not retracting.
Old Dec 22, 2019 | 04:11 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
You were able to get them in with the C clamp?
Old Dec 22, 2019 | 05:20 PM
BradsB4C's Avatar
Yes, got them pushed back in and re-installed on the car no problem. Spun the wheel before I let the jack down and it spun freely. When I tried the brakes again the wheel locked back up. The pistons wont retract, the brakes are constantly being applied.
Old Dec 22, 2019 | 05:21 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Might be the brake hoses, when they get old they can prevent fluid from going back to the reservoir
Old Dec 22, 2019 | 05:37 PM
BizJetTech's Avatar
Pull the brake line off the caliper and see if you can get the the piston retracted enough to remove it.
Old Dec 22, 2019 | 06:19 PM
NoEmissions84TA's Avatar
True. The hoses can act like a one-way valve.
Old Dec 22, 2019 | 07:00 PM
BradsB4C's Avatar
Thanks for the tips!!! Looks like everyone is pointing to the hoses. I will update when I try it.
Old Dec 22, 2019 | 07:45 PM
Drew's Avatar
Optionally, crack open the bleeders. If they can be pushed in easily with the bleeders open and brake fluid squirting everywhere, the hoses are trash.
If you haven't changed the hoses recently, you need to change the hoses.
Old Dec 23, 2019 | 05:29 AM
Bigjj's Avatar
it is definitely the hoses I work in an auto parts store,see this all the time
MikeS
Brakes
Jan 2, 2023 12:59 PM
Daishi
Brakes
20
Jul 21, 2007 08:16 PM
Alexcoqui
Jul 30, 2004 06:52 PM
CamarosRUS
Brakes
29
Jan 28, 2003 08:41 PM
davehamilton
Sep 8, 2001 04:31 PM
