Rear disk conversion 1992 Camaro
Old Jan 17, 2020 | 11:15 AM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
1992 Camaro Z28 A4.
I'm converting the old drums on the stock 10 bolt to disks. From what I've read the master cylinder doesn't need to be changed out but I will need a new pro. valve. What valve you you recommend? Links, costs, etc. I think I'd prefer an adjustable version but not sure what I'm looking for. Thanks.
Old Jan 17, 2020 | 12:08 PM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
Re: Rear disk conversion 1992 Camaro
Originally Posted by MeenZ28
1992 Camaro Z28 A4.
You don't need the whole valve. Just do the spring upgrade to your stock valve. Do a search for it on here or google.
Old Jan 17, 2020 | 12:09 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Ssbc and summit racing both make a adjustable prop valve. Or you can find the thread here that uses a granger 1NCR5 spring to replace the stock spring in the prop valve.
Old Jan 17, 2020 | 12:11 PM
Engine: Lb9
Transmission: M20
https://m.grainger.com/mobile/produc...searchBar=true
Old Jan 17, 2020 | 12:17 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Some cars are just fine with the stock drum prop valve.. I've done a few and left the drum valve and they are just fine.
Old Jan 17, 2020 | 01:23 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
+1
I hooked up a 4th gen rear with disk brakes and didn't change anything else, in my particular case it was not needed to change the prop valve.
Stops better than anything else I've owned over the years.
Old Jan 20, 2020 | 02:15 PM
MeenZ28's Avatar
Transmission: A4
I appreciate the advise guys. This is why I love this board!
WhiteBlaze
Brakes
Jun 21, 2012 01:09 PM
86Z
Brakes
Jun 4, 2006 10:38 AM
The Chad
Brakes
Feb 7, 2006 09:46 PM
