Need help ls1 front brake swap
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I have a 88 gta
I got my ls1 front brake swap and I did the driverside front and I think I got the caliper on backwards
I did every thing went to put my 16 gta rim and snugged the nuts and the rim locked solid and hits the caliper
I just left it for now
my driverside caliper I picked has the bleeder screw down 6oclock
I think I need to get the other one
can anyone tell me why everyone told me the swap fit my 16 gta wheels and now it's doesn't
what do I do
what do I do
Engine: 383 built
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: Need help ls1 front brake swap
The bleeder goes up. The air will pocket at the highest point of the caliper, so that's where it makes the most sense to have the bleeder screw.
Engine: 383 built
Ok great
ty all
so bleeder screws up
and the 3/16 spacer
I can try washers first just to see if it clears with 5 washers untill I have to order a wheel spacer
ty all
and the 3/16 spacer
Car: 85 Iron Duke, 88 GTA and 92 TA
You need a 1/4" or 6,xx mm spacer with the crosslace rims. Otherwise it doesn't fit. Had the same problem years ago.
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
The factory spacer used in aluminum drum brake cars works also to space the wheel it's 3/16" as well
Engine: 383 built
What if I switched my rear to front and front to rears
would it get rid of my rims sticking out 1 inch on the front
right now they are like sticking out 1 inch from the wheel well I don't like it
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
FWIW, I have four rear GTA wheels on my Formula and LS1 front brakes. Mounting the rear GTA wheel up front required the factory rear spacer to clear the calipers. My car was originally a rear drum car, so it came with the spacers. I did a rear disk conversion so they were no longer needed for the rear wheels.
Engine: 383 built
mine does and it looks dumb
do you have a pic I can see of the front
Engine: 383 built
I have disc brakes rear stock
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Yes, you can swap rears to the front and fronts to the rear with a removeable rotor setup, but you still need that spacer to clear the wheel
Engine: 383 built
Engine: L31 350 TPI
Yes, it will fix this problem if you put the rear wheels on front. The LS1 front brake swap increases the front track by about the same amount as the offset of the rear wheels as compared to the front wheel offset. But the GTA wheels require the small spacer to clear the calipers. The standard Formula wheels did not need the spacer.
Engine: 383 built
and I did order 4 small 3/16" spacers may be here fri
God I hope your right
Engine: 383 built
ty
Engine: L31 350 TPI
Engine: 383 built
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
@bensbaby Can you post pictures of your progress with the LS1 front brake and your wheels? I'm going to be doing the LS1 front brakes here in the near future and I also have the GTA wheels.
Engine: 383 built
You were right
front to back and back to front and a 5mm wheel spacer metal ones wilwood 3/16"
and I'll get pics after tomm
honestly I'm blown away
it fixed the looks issue
it's amazing
it's amazing
Engine: 5.7 HSR
