LS1 front brake swap
Old Oct 15, 2003 | 10:53 PM
JERRYWHO's Avatar
Has anyone done this and have it on the road. The local parts yard has a 2001 Camaro with 19,000 miles on it and I can get all the brakes off it. The rear setup is very easy swap, but all the searching I have done shows no front swaps on the road today.
Jerry
Old Oct 16, 2003 | 08:54 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
AFAIK, no one has installed it yet. I will be making the bracket and putting the thing together this weekend, but I don't have 17" wheels to run it anyway.
Unless someone local lends me a set for a week...
Ed
Old Oct 16, 2003 | 01:50 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
I'll lend you a car with 17's to put the brakes on Ed .
Old Oct 16, 2003 | 03:27 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
ed,
You don't need 17's with the LS1 breaks. All you need is 16's
Old Oct 16, 2003 | 08:08 PM
ebmiller88's Avatar
No kidding Luke??? I could have swore they were required. I'll just try the ones I have then, but if by chance they don't fit. I'll call ya mark...your car can be the test mule.
I have noticed that the LS1 calipers don't have the stiffening ribs like the C5s do so I can assume there is more clearance given there.
Ed
Old Oct 16, 2003 | 09:35 PM
z28cdoyle's Avatar
Car: 85 IROC
Engine: 355
Transmission: Tremec 5 speed
Welcome to the LS1 brake crowd Jerrywho. I'm in the process of doing his swap but am only partly thru so far.
Ed,
Everything I have read on the LS1 brakes is that they will clear 16" wheels just fine. The C5 brake swap requires 17" wheels because the rotor is 13" in diameter.
Old Oct 16, 2003 | 11:22 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
The camaro LS1 brakes have 12 inch rotors so they will clear 16 inch rims. The reason the C5 setup doesn’t clear 16’s is it has 12.75 rotors.
I would love to test the setup on my car but right now it doesn’t have a engine in it so I can’t.
Old Jan 28, 2004 | 11:04 AM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
From what I understand all 98+ camaros had the bigger disc brakes, that means the base models had them too, I doubt gm put 17" wheels on all the basemodels some probably came with the steelies and I know they werent making 17" steel wheels.
Old Feb 15, 2004 | 02:14 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Anymore info on this?? I bought a wrecked '98 and I'd like to put them on my '91 GTA.
Old Feb 15, 2004 | 09:24 PM
ebmiller88's Avatar
You need to go to the FAQ forum. Look here:
https://www.thirdgen.org/techbb2/sho...hreadid=183169
Ed
Old Feb 15, 2004 | 09:55 PM
25THRSS's Avatar
Why would you need 17's for ls1 brakes with the majority of them had 16's? My Z28 has 16's and factory ls1 brakes. They stop quite nice with cross drilled rotors and green stop pads.
Old Feb 16, 2004 | 07:27 AM
ebmiller88's Avatar
LS1 brakes only need 16" wheels, the C5s require 17"s.
Ed
Old Feb 16, 2004 | 09:37 PM
25THRSS's Avatar
On another note, you can even run 15's with the Ls1 brakes if you do a bit little grinding on the calipers. This is a popular mod for those who use 15's with their slicks.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
