There was a thread from years ago about machining the hubs for LS1 rotors
Old Oct 30, 2020 | 01:33 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
And I've seem to have lost it.
Anyone have the link?
Old Oct 30, 2020 | 08:38 AM
rgauder's Avatar
Car: 1987 Trans Am
Re: There was a thread from years ago about machining the hubs for LS1 rotors
I turned mine down to 5.87" to fit behind all brake rotors.
Old Oct 31, 2020 | 07:14 PM
BBU.COM's Avatar
Top Answer: 1
I always bring them down to 5.80, stock LS1 hubs were 5.75 fyi....ream your wheel stud holes for a .005-.007 fit for what ever stud you use
Old Nov 1, 2020 | 12:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I changed my mind and will be be placing an order for your Al hubs and brackets😎
Old Nov 1, 2020 | 03:42 PM
BBU.COM's Avatar
Top Answer: 1
Awesome! you will be very happy with those!
Old Nov 2, 2020 | 02:56 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
What sold me was when I looked a few days back, and noticed they run the larger bearings in them. I’ll email you tomorrow when I have my laptop. I forgot what we’d talked about a few months ago. That fanged age thing again....
Old Nov 3, 2020 | 07:25 AM
BBU.COM's Avatar
Top Answer: 1
They do have the 1LE bearings but with the stock offset of the std hub. .800 thick decks and heavy webbing on the inboard side to support that deck. The best feature beyond all of those is the register is .800 tall, this means the rotor and the wheel have plenty to center off of, your stock rotor cut down into a hub is marginal with about .400 of register usually. After you stack a rotor you may have less than .100 for the wheel and you know they have a generous taper on the pilot hole for the wheel. In some cases the wheel may not even register off of that, then your dependent on the studs to center it. I don`t know if you have seen this but Lsx Matt did a video using these hubs not too long ago, he even has a code to get a discount on them if you watch it through.
Old Nov 3, 2020 | 08:35 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
https://youtu.be/zDsRB-r4oJA
Informative!...and I will use the code
Thanks Scott
Nighthawkf-117
Brakes
Jun 30, 2014 05:59 PM
ringo234
Brakes
Apr 1, 2012 03:45 PM
seiplentz
Brakes
Jan 4, 2010 05:45 PM
SheldonZ28
Brakes
Mar 18, 2008 01:38 AM
