Putting a 9" ford rear in my Third gen and want to switch to disk brakes.
Old Mar 2, 2021 | 12:31 PM
jbander's Avatar
What proportioning valve should I be looking at.
Old Mar 2, 2021 | 10:04 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: Putting a 9" ford rear in my Third gen and want to switch to disk brakes.
This is what I have
https://www.summitracing.com/parts/sum-g3905
I put in a 9" with disk brakes as well
Old Mar 2, 2021 | 10:16 PM
jbander's Avatar
Thank you for the responce ,How does that work when there is only one intake and one outlet, how do you set that up for front and back. One more thing if I may, if you have a 3rd gen F body , I would like to know if a stock driveshaft fits with the 9" ford and what gears are you running with your ring and pinion.
Old Mar 2, 2021 | 10:22 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
For the one inlet/outlet, you'll have to get a splitter. I'll try to take a pic tomorrow.
Yes I have a f-body(91 GTA)
A stock driveshaft will work with a 9", just need to get another u-joint to hook it to the yoke.
I have a 4.11 in my diff.
What brand 9" are you going with?
What axle?
Old Mar 3, 2021 | 12:21 PM
jbander's Avatar
Originally Posted by LB9GTA
This is what I have
What axle?
Again thanks for the response, You have helped me a lot, whats your thought on a duel outlet proportioning valve?. https://www.speedwaymotors.com/Ford-...1048345-31-456
https://www.quickperformance.com/QP-...kage_p_40.html
dieseldennis
Brakes
Apr 26, 2009 11:09 PM
chixon
Brakes
Dec 20, 2007 02:31 AM
Yellow87Cam
Brakes
Dec 16, 2006 09:45 PM
Scott_92RS
Dec 2, 2001 01:36 AM
