87 combination valve modification
Old Dec 19, 2021 | 05:56 PM
Ponch85rs's Avatar
Car: 1987 Chevrolet Camaro Sport Coupe
Axle/Gears: 3:42
Greetings,
I am currently in the process of converting my 87 (stock rear drum) over to C5 Disks. From what I have read on here,, I would need a 1LE combination valve for optimum performance.
I have also read about the "upgrade" you can perform on the stock valve (the stronger spring.)
my question is, do I need to purchase the 1LE valve, or can I modify my stock valve so that it is compatible?
Old Dec 19, 2021 | 06:17 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: 87 combination valve modification
You can fiddle with spring rate in your existing combination valve. The thread linked below will give you a fighting chance to make reasonable choices.
Real 1LE combinations valves are not very common. If you can find one then buy it and use it. The code stamped on the valve is also described in the link below.
https://www.thirdgen.org/forums/brak...ng-torque.html
Old Dec 20, 2021 | 11:13 AM
Ponch85rs's Avatar
Axle/Gears: 3:42
thanks brother
funkdubie
Mar 8, 2009 06:38 AM
MikeH
Brakes
Apr 8, 2007 08:06 PM
mystikkal_69
May 15, 2002 10:58 PM
