Calculating braking torque
Car: '89 Firebird
Engine: 7.0L
Below is a method to estimate braking torque of any brake package. Topics include,
* How to calculate braking torque
* Explanation how the stock proportioning valve works and how to calculate the proportioning ratio
* How to modify your stock prop valve to produce a different proportioning curve
* Lists of physical data of braking systems
You're going to see a little bit of rounding error here and there because I'm copying numbers from my spreadsheet. Just go with the flow and don't worry about it.
Step 1: Applied force to Master Cylinder
Assume 100 lb of foot force on the brake pedal. This is a usual assumption for heavy braking. Pedal ratio is 3.3. The force applied to the master cylinder is,
manual force = (100 lb) * (3.3) = 330 lb
The brake booster also assists. Assume 40 kpa manifold pressure. Booster has two 9 inch diaphragms and operates near 80% efficiency. Atmospheric pressure is 100 kpa, so the differential pressure across the diaphragms is,
air pressure = (100 kpa - 40 kpa) = 60 kpa
The force applied to the master cylinder from vacuum assist is,
boost assist force = (total area of diaphragms) * (vacuum pressure) * (booster efficiency)
boost assist force = 886 lb
So the total force applied to the brake master cylinder is,
master cylinder force = 330 + 886
master cylinder force = 1216 lb
Step 2: Front and rear brake line pressure
This first part is very simple. Assume the master cylinder has a 1" cylinder bore diameter.
front line pressure = (master cylinder force) / (master cylinder bore area)
front line pressure = (1216 lb) / (0.785 inch2)
front line pressure = 1548 psi
The rear line pressure is the tricky part. The proportioning valve "proportions" (reduces) the rear line pressure by some amount. I'm not going to explain how that works quite yet. Just assume for now that the prop valve reduces line pressure to 59%.
rear line pressure = (front line pressure) * (proportioning)
rear line pressure = (1548 psi) * (59%)
rear line pressure = 911 psi
Step 3: Front and rear caliper clamping force
The clamping force of the caliper on the brake rotor is pressure multiplied by piston area. For this example I'll use C6 Z06 Brembo 6-piston front brakes with 33 mm pistons, and LS1 F-body single piston rear brakes with 45 mm piston. Note: 6 piston calipers have opposing pistons so the clamping force is half, or equivalent to the area of 3 pistons.
Front piston area = pi * [ (33/2)^2 + (33/2)^2 + (33/2)^2 ] = 2566 mm2
Front piston area = 3.977 inch2
Front clamping force = (front line pressure) * (front piston area)
Front clamping force = (1548 psi) * (3.977 inch2)
Front clamping force = 6156 lb
Rear piston area = pi * (45/2)^2 = 1590 mm2
Rear piston area = 2.465 inch2
Rear clamping force = (Rear line pressure) * (Rear piston area)
Rear clamping force = (911 psi) * (2.465 inch2)
Rear clamping force = 2246 lb
Step 4: Braking torque
The clamping force causes drag on the rotor that is proportional to the pad coefficient of friction. For this example I am going to assign 0.35 coefficient to the rear brakes, and 0.4 coefficient to the front brakes because they tend to get hotter.
drag = (clamping force) * (pad coefficient of friction)
Front drag = (6156) * (0.4)
Front drag = 2462 lb
Rear drag = (2246) * (0.35)
Rear drag = 786 lb
The drag force is applied at a radius to generate braking torque. C6 Z06 Brembo front rotors are 14" overall diameter, and rumor is the pads ride on an effective diameter of 11.968". Likewise, the LS1 F-body rear rotors are 12" overall diameter, and rumor is the effective diameter is 10.01". (The effective diameter is the centerline where the pads apply force.)
Front brake torque = (front drag) * (effective diameter / 2) * (2 sets of brakes on front)
Front brake torque = (2462 lb) * (11.968 inch / 2) * 2
Front brake torque = 29465 lb-inch
Front brake torque = 2456 lb-ft
Rear brake torque = (786 lb) * (10.01 inch / 2) * 2
Rear brake torque = 7868 lb-inch
Rear brake torque = 656 lb-ft
So this brake package has a Total brake torque of 3112 lb-ft, with 79% front and 21% rear.
Rear drag = 786 lb
Car: '89 Firebird
Engine: 7.0L
Re: Calculating braking torque
The Components
First order of business is to understand how the valve works. High pressure fluid from the Master Cylinder enters the Proportioning Valve. Fluid passes through unaltered at full line pressure to the front brakes (not shown here). Fluid to the rear brake lines gets proportioned, meaning the pressure is altered. The task of proportioning the rear brake line pressure is done by a Piston, Cup-Seal, and Spring. And it's genius how they did it. A diagram of the rear brake passage is shown below.
The piston sits in the prop valve with a spring on one end and a cup-seal on the other. When the piston moves to the right it pushes against the cup-seal and deforms the seal. The deformation cause the cup-seal to lose its ability to hold a seal and fluid passes thru to the rear brakes. (ya, I know, it's not intuitive) When the piston moves to the left, the cup-seal can reform and make a seal again and stop fluid flow to the rear brakes.
Step 1: When brakes are applied
The native state of the valve is with the spring pushing the piston to the right and allowing fluid to flow to the rear brakes. Fluid pressure in the forward chamber is same as pressure in the rear chamber. The key thing here is that the piston is not fully submerged in the fluid -- one end of the piston protrudes out of the chamber into the outside air (atmosphere). As fluid pressure rises in the brake line it causes a hydraulic force to be applied to the piston that tries to push the piston out of the valve into the atmosphere, and the only thing resisting it is the spring. During this period the pressure will rise at a 1:1 ratio (same) with the front brake lines because the cup-seal is allowing fluid to pass freely to the rear brakes.
Step 2: The hysteresis point - the point where rear brake proportioning begins
Eventually the spring is overcome and the piston will move far enough to the left that the cup-seal will form a seal and shut off the rear brake line and stop fluid flow. This is called the hysteresis point where pressure to rear brake line begins to be "proportioned". From now on pressure to the rear brake lines will increase at a slower rate than the front brakes, with a slope that is equal to the "proportioning rate" of the valve. Increasing the spring rate will increase the rear line pressure where hysteresis occurs.
(Note: Saying a prop valve reduces rear line pressure is a misnomer. The pressure is actually increasing as the brake pedal is pushed harder, but the rate of increase is less than the rate of increase in the front brakes. The rear brake line pressure is "proportioned" as a ratio of the front.)
Step 3: The proportioning rate
At this point the rear line pressure is stagnant because the line is sealed off from the front chamber. As pressure rises in the front chamber it causes a hydraulic force to be applied to the piston that pushes it to the right again. As the piston moves right the cup-seal is deformed and pressure can rise in the rear chamber again..... but this time pressure doesn't equalize with the front. From now on the rear line pressure will always be less than the front line pressure. The secret is in unequal surface areas for hydraulic pressure to act on.
The piston is basically stuck floating between the point where the cup-seal opens and closes. The forces pushing the piston to the right are in balance with the forces pushing the piston to the left. However, the hydraulics in the rear chamber are pushing against a larger surface area than the hydraulics in the front chamber, so the rear chamber ends up at lower pressure than the front in order to balance forces. And that's how the prop valve proportions rear brake line pressure.
This situation won't change until the brakes are released and the pressure goes below the hysteresis point again.Doing The Math
All the calculations in this example are for a 3rd gen "NB code" prop valve. Some measurements of the piston are needed.
We know that inlet pressure equals outlet pressure in the range of operation before reaching the hysteresis point. And the hysteresis pressure is found by,
Assembled spring force = (hysteresis pressure) * (spring tube area)
(9.8 lb) = (hysteresis pressure) * (0.06335 inch2)
hysteresis pressure = 155 psi
After the hysteresis point, rear line pressure is found by the following method.
Assembled spring force = (spring rate) * (compressed length)
Assembled spring force = (19.6 lb/inch) * (0.5 inch)
Spring force = 9.8 lb
Calculate the area of the piston on which the hydraulic pressure acts to cause a force to the right (--->)
Area on inlet side = (shelf area) - (spring tube area)
Area on inlet side = [ (shelf diameter)^2 - (spring tube diameter)^2 ] * pi / 4
Area on inlet side = [ (0.420)^2 - (0.284)^2 ] * pi / 4
Ai = 0.0752 inch2
Calculate the area of the piston on which the hydraulic pressure acts to cause a force to the left (<---)
Area on outlet side = (spring tube area) + (Ai)
Area on outlet side = [ (0.284)^2 * pi / 4 ] + (0.0752)
Ao = 0.1385 inch2
Calculate the total force by which the piston is pushed to the right (--->)
Total force = (Hyd force inlet side) + (spring force)
Total force = [ (Ai) * (master cylinder pressure) ] + (9.8)
The forces must balance on the inlet side and outlet side of the piston. The right side of the piston has only a hydraulic force element. Calculate the hydraulic pressure in the outlet.
Total Force = (Hyd force outlet side)
Total Force = (Ao) * (rear line pressure)
rear line pressure = (Total Force) / (Ao)
And now you have the ability to calculate rear line pressure. If you iterate this a few times you can also generate curves for any stock prop valve, such as below.
Car: '89 Firebird
Engine: 7.0L
Modifying the OE prop valve
The "Grainger spring swap" is a well known modification to get the rear brakes to participate more. As shown earlier, swapping springs changes the hysteresis point but it does not change the proportioning rate of the valve. By swapping springs you end up with two parallel curves with one higher than the other (see graph below).
I've read a lot of threads on this site about the Grainger spring swap and one thing is clear -- different people get different results, sometimes wildly different. The reason is because they're only paying attention to advertised spring rates and don't understand what's really happening. It's not the spring rate you need to pay attention to. The key feature is the spring force that is applied to the piston when the spring is fully assembled into the valve. And that spring force will be different depending what valve you have.
The spring sticks out the end of the valve body before assembly and the spring is compressed when the vent cap is screwed in place. The spring force on the piston is,
spring force = (spring rate) * [ (free length) - (compressed length) ]
There are multiple piston designs that I know of, maybe more. The NB code disc brake piston I have results in a spring compressed length of 1.0 inch. I've never had a drum brake piston in my hands, but it definitely has a longer pocket for the spring and the spring is not compressed as much. So putting the same spring in a disc valve vs. a drum valve will give two different results. But there is a much bigger difference than that between disc and drum valves. The other factor is the piston "spring shaft diameter", and it is different between the various valves.
The shaft diameter also is a powerful tuning tool and has a massive effect on how the valve behaves. A smaller spring shaft diameter will increase the hysteresis point, but it will also increase the proportioning rate of the valve (slope of the curve). The chart below compares a mid-'80s disc brake NB valve to a later LF valve used on the 1LE cars. The LF valve uses the same spring as a stock NB valve, but has a smaller piston shaft diameter that results in a more aggressive proportioning slope. Even swapping out for a 2x more powerful spring in the NB valve doesn't make up for the difference at high braking pressures. So it's no wonder the later disc/disc valves are so desirable: they have a higher proportioning rate.
But don't throw away your drum brake valve yet! Turns out the drum valves have an even smaller piston shaft diameter than the later disc/disc LF valves, and that means an even higher proportioning rate. All you need to do to make your drum valve work is choose the right spring. For example, tossing a Grainger 1NCF1 spring into your old NC code drum valve will produce more aggressive braking curve than the later model LF valve used on 1LE cars.
So now you know how to do the calculations and what to watch for. Doing so can literally make the difference between lackluster brake performance and having a panic attack when rear brakes lock. At the end of the day these calculations are only an aid to help guide you which direction things will move with a particular change. You'll still need to get out there with the car to see what happens and go from there.
Car: '89 Firebird
Engine: 7.0L
Here is the technical data needed to do calcs. Some of this data has measurements to back it up, some I am guessing. I need help from members here to check & verify. The better we make these data tables the better the results.
The "Spring Force Assembled" is what you use for calculations to create prop valve curve. One column is the force when spring is assembled with a piston from disc/disc valve. The other column is the force when the same spring is assembled to a piston from a drum valve, because the spring doesn't compress as much. I am looking for volunteers to take some measurements of stock parts for me. Just post up and I'll explain what I need from you. I think the stock springs are music wire and I highly recommend staying with music wire.
Dimensions of the piston inside the prop valve. A lot of this is guesses and I need help from members to put the right data in here.
Stock 3rd gen prop valve codes. The broadcast code is stamped onto the body of the prop valve.
This doesn't help with calcs but it's hard to find information that I think is worth sharing.
Car: '89 Firebird
Engine: 7.0L
And here is the information needed about the brakes. I am unsure about numbers in red text. And there are blanks in the table that I would like to get filled out. Again, hoping people can check & verify to help get this data right.
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Still wrapping my head around all of this info... Thank YOU for the hard work in compiling it!
Car: '89 Firebird
Engine: 7.0L
You're welcome. It was a fun little hobby last winter.
This came about because I kept guessing and making changes to improve braking performance and wasn't getting the results I wanted. Finally got tired of all that hassle and figured this out. Being able to run calculations and comparisons in a spreadsheet made all the difference in the world. I suddenly knew what changes to make and what to expect. It was freakin' fantastico.
I have a spreadsheet where you can choose the front and rear brakes from a pick-list and it will do the calculations for you. But it's not as user friendly as you might think so I never offered it up to everyone. I can give you a copy if you really want it but you're kind of on your own using it.
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
I was able to follow along with the math and have no complaints on the explanation, it follows engineering logic as far as I can see. Very nice work and strong explanation; well done. Are you a mech engineer?
The thing that kept occuring to me as I read the threads on swapping springs is the effective spring rate over actual travel seemed to be talked about. I think you have shown that this is an important pc of the puzzle. Same with the spool valve dimensions.
Car: '89 Firebird
Engine: 7.0L
Thanks for the feedback. Your input is appreciated and valued!
By education, yes, but have forgotten 99% of everything by lack of use. You know how it is, 90% of engineers run elements of the business while 10% or less are the hardcore designers. I'm the 90%.
Car: 1987 IROC-Z
Engine: L98 5.7L
You have stated assumptions and maintained units in your calculations so you haven't forgotten too much! I'm a mech eng tech that does design work and likely wouldn't have met the bar of your post.
In consideration that there are a number of assumptions in the calculations would it fair to suggest that going through this exercise is primarily about understanding the concepts and how the components impact the outcome - and then to use the output as a comparison tool vs. an actual specific calculation of one's car? At least I see the greatest value here is to evaluate how changing components changes the relative output more than defining the actual results. I think that is why you have suggested that results ought to be confirmed individually.
Car: '89 Firebird
Engine: 7.0L
Exactly. I used it to make relative comparisons, and decide if a change was directionally correct or not. I already had seat time in my car so I wasn't flying blind either.
There are some rule of thumb guidelines for overall braking torque and front/rear bias, depending on application. I found some good info at pro-touring.com where the guys from Kore3 and Ron Sutton are talking about brakes.
Car: 1987 Formula 350
Engine: TPI 383 Stroker
It’s funny when you look at the math so many common brake system beliefs just get thrown out the window. Such as six piston calipers (or eight piston, 12 piston, etc...) have more braking force than single piston calipers.
When the reality is it’s just a function of total piston area. You can have one large piston or multiple tiny opposed pistons if they (divided by 2) add up to the same total piston area they will brake with the same force.
Or that by upgrading to larger brakes (i.e. more braking force) will make your car stop In a shorter distance. When the reality is adding more braking force to the front generally results in a longer stopping distance. ( Quick hint, on a normal street car slightly increasing rear brake force generally results in shorter breaking distances).
But I guess that is the beauty of a brake proportioning valve.
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Multiple pistons versus single piston doesn't necessarily change total force applied (depends on cylinder sizes), but it spreads it more equally out across the pad surface.
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Qwktrip, this is a very nice thread and summary and would be a good stickie
Also anyone interested in understanding more about design of brake systems, the book Brake Design and Safety by Rudolf Limpert is an excellent resource
IROCZman15
Brakes
16
Mar 25, 2019 10:42 AM
