rear disc brake caliper
Old Jul 14, 2022 | 04:11 PM
miche25's Avatar
Car: Camaro 1984
Camaro Z28 - 84
If I order only a rear disc brake caliper, do I need to request a side (right or left). Are they identical?
Old Jul 14, 2022 | 04:27 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Re: rear disc brake caliper
Generally, I would think they were different, but I see a schematic, and one is mounted opposite the other, so maybe they are identical. But I can't say positively. Sorry. Interesting question tho.
Old Jul 26, 2022 | 12:04 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
82-88 the cast iron rear calipers were the same, was it 88-89 when they started introducing the rear PBR calipers which had left's and right's.
Old Jul 26, 2022 | 12:21 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
I'm basing this on memory but the early rear disc calipers were the same left to right. D/S caliper is mounted rearward of the disc while P/S is forward of the disc. Allowing the casting to be the same and keep the bleeder "up". The cables orient from opposite directions too iirc.
Old Jul 26, 2022 | 03:26 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Good to know. Thanks for the info.
Sdallaire
Brakes
May 6, 2017 05:19 PM
Lucid
Brakes
Jul 7, 2013 05:57 PM
KlayBuRn
Sep 25, 2002 03:05 PM
