what is "performance package" for factory brakes
Old Mar 13, 2023 | 10:23 PM
kt350's Avatar
Car: 88 iroc-z
Engine: 5.7tpi
Transmission: auto
Need some help I went online with Rock Auto to order brake caliper kits for my 88 5.7 IROC and they list standard, heavy duty (except performance package), heavy duty with performance package and performance package. How do I know what I have, the RPO codes haven't helped.
Old Mar 14, 2023 | 12:30 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: what is "performance package" for factory brakes
Performance package RPO for your car is 1LE, check your RPO codes for that...however you likely have the regular single piston calipers so just pick one WITHOUT performance package or just standard brakes. Another easy way to check on your car is compare the caliper pictures or pull one and see if it has one piston or two, single piston is regular brakes and two piston is the performance package. IIRC there were very few 88' IROCS with 1LE but don't quote me on that.
Old Mar 14, 2023 | 04:17 AM
kt350's Avatar
Car: 88 iroc-z
Engine: 5.7tpi
Transmission: auto
Thanks for that, I didn’t know if there was another performance option other than the twin pots for a 1LE. It’s a bit strange that RockAuto is listing parts for the performance package when they only built about four of them in 88.
Old Mar 14, 2023 | 06:42 AM
Engine: 5.7 L98
Yeah it does not make much sense but at least they support the cars/parts, that and some ppl have upgraded over the years to that set up.
Old Mar 14, 2023 | 11:11 AM
If you have to ask, you don't have it.
"Performance" option calipers are easily identified by the aluminum calipers, with fins; as opposed to the old cast-iron calipers that are smooth and rusty.
dm3k
Brakes
Aug 29, 2015 01:53 PM
DirtyracingGTA
Brakes
Apr 22, 2008 07:29 PM
Hoop88Z
Brakes
Jun 21, 2005 09:44 AM
md65000
Mar 27, 2004 02:56 PM
SCCAjunkie
Apr 23, 2001 07:20 AM
