brake bleeding tool
brake bleeding tool
Trying to bleed the rear brakes on a 1986 Camaro, and the bleeder is 8MM and situated just above the brake line and its recessed so it only seems like a socket will fit to loosen it. Question is how do you get a tool on the bleeder with a hose on it so you dont get brake fluid all over?
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: brake bleeding tool
Just put a catch bucket under it and let the fluid drip, if you can't get a box end on it.
05kcilS
Jun 9, 2003 07:24 PM
