Choo Choo Chuga chuga when braking to a stop
Old Jun 4, 2024 | 01:06 PM
Extrafitkid's Avatar
Car: 1986 TRANS AM
Engine: LB9
Hello all,
Started to drive my 1986 TA after replacing tons of parts woman owner, I bought it had original everything, water pump leaking, Starter, Power steering pump, AC Compressor etc..
Anyway My Rotors "look" good, Brake shoes "look" thick, and new calipers but when I brake a feel this mild chugging or surging back and forth to a stop in the front its enough to notice. Anybody else had this?
"look" just mean "looks" not sure maybe disc warped?
Thank For Any Thoughts!
Old Jun 4, 2024 | 01:23 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Choo Choo Chuga chuga when braking to a stop
Discs could be warped from a panic stop. It doesn't take much to overheat the stock brakes on these cars. You could take them to get turned but the stock rotors are cheap to replace anyways.
It would be a good time to check your brake hoses too. They may be swelling up if they are old.
Old Jun 4, 2024 | 07:42 PM
Car: 1986 TRANS AM
Engine: LB9
I Really Appreciate this Input from you helps to move forward !
Old Jun 4, 2024 | 10:18 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
The other thing that warps perfectly good discs is over torquing the wheel lug nuts.
When you see a mechanic grab that impact wrench....
Old Jun 5, 2024 | 10:45 AM
Beeman's Avatar
You replaced tons of parts, did you replace any brake parts? Most blame the rotors without checking runout or checking thickness. Most do brake replacement and don't disassemble the caliper sliders and replace all of the hardware. It's an almost 40 yo old vehicle, everything is worn out.
Old Jun 5, 2024 | 06:25 PM
Car: 1986 TRANS AM
Engine: LB9
Pfft It not 40 yet it's only 38yrs old
They're fine ....
Chuckle Ya good point ....
dragsta
Brakes
Nov 17, 2017 06:55 AM
t/agta
Brakes
Oct 15, 2007 03:31 PM
89RallySport
Jul 23, 2004 10:47 AM
ghettocruiser
Oct 9, 2003 11:11 PM
hurricanerugger
Dec 16, 2002 06:54 PM
