Brake pedal pulsing??
Ok, this is really weird. I just redone all my front braking system, calipers, hoses, new rotors, pads, hardware. Drove perfect for 3 or so months then my car flooded due to bad t-top seals. I got pissed and parked the car for about a month and a half. After being theatened to be towed from the front of my house i went to move it and my brake pedal is pulsing up and down very bad with poor stoping capability. No shaking in vehicle, steering wheel, anything...just the pedal is bouncing up and down and i cant stop. Booster? Any ideas greatly appreciated
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Warped rotor(s). Do you have rear disc brakes or drums? Was the E-brake engaged the entire time the car sat?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Probably then the rotor has furry rust all over it except for the spots where the pads were.
Car: '87 Cam RS V6
Engine: Top Secret
Originally posted by 89RallySport
Will just siting warp a rotor? But yes, the e-brake was engaged the whole time it sat and it was seized when I disengaged it.
Car: '87 Cam RS V6
Engine: Top Secret
Yah i just knoticed a good amount of surface rust on the rotor, should i cut or just replace? Woulndt a warped rotor shake the steering wheel as well though?
With that said, it is imparitive that you DO pull it now and then to 1) keep it functional, and 2) keep the pads adjusted up to par- e-brake mechanisms are generlly self adjusting by pulling the handbrake lever up and down a few times(they won't over adjust)
Just have the rears turned to true and clean them up.
Night rider327
09-02-2015 04:17 AM
