Brake fluid leak
Old Sep 3, 2024 | 06:12 PM
2016eversince's Avatar
Car: 91 Trans Am GTA
Transmission: Auto 4-Speed
Brake fluid leak
Went downstairs to get something from the car and saw a large puddle of what i’m presuming is brake fluid. It can't be oil because my oil is dark right now (needs to be changed) and it feels like brake fluid on my hands. A few days ago I checked the reservoir as the brakes were feeling uneffective and noticed it was almost completely empty. Filled it back up and a friend looked at the cylinders while i was at work, but he didn’t notice any issue down there. Does anybody have any advice?
Old Sep 3, 2024 | 06:47 PM
Re: Brake fluid leak
Jack up the car, take off the wheels, and LOOK AT IT.
Old Sep 3, 2024 | 07:58 PM
Thanks but i've already looked at it with the wheels off. Thought i put that in the post. Was looking for pointers if other people experienced the same issue...
Old Sep 4, 2024 | 07:53 AM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Rusted steel line, probably the one for front right. It goes along the k-member.
Old Sep 4, 2024 | 11:42 AM
It's a failed brake part. Probably one of:
Steel line
Rubber hose
Caliper
Prop valve
Master cylinder
Wherever the fluid is coming from, that's what's bad. Whenever I've had that issue, which unfortunately has been quite a few times on quite a few vehicles over the decades, I simply LOOKED AT IT, located and observed the source of the fluid, and proceeded from there. Not sure what other options there are for handling it, or what difference it makes to YOUR situation, which part(s) have failed on others' cars.
87camaroPOS
Brakes
Aug 22, 2011 07:16 PM
MeyoungMoney
Brakes
Jun 15, 2009 07:06 AM
My1stRS
Dec 3, 2002 11:38 AM
KeithO
Mar 11, 2002 02:33 PM
junkyarddog
Jul 16, 2001 12:32 AM
