90 formula brake leak?
Old Jun 15, 2009 | 12:05 AM
MeyoungMoney's Avatar
Car: 1990 Pontiac Formula
Engine: Boat Anchor 305 wish I had an LS1
Transmission: Automagic
I noticed a puddle under my car a few days ago and reasonable i checked it out to see if it was oil or trans fluid but it wasnt either so i moved the car and checked the next day there was no fluid on the ground i checked my oil and trans fluid again and the powersteering all was fine so i look and one on my rims was wet and there was a puddle under it the next day and what could it be i thought maybe brake fluid but my brakes still stop fine but everyonce in a while there is a loud squeak from that side so im looking for any suggestions of what i should do and if you could throw out a price estimate please do so thanks
Old Jun 15, 2009 | 01:06 AM
STRIKER911's Avatar
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Re: 90 formula brake leak?
Pull the wheel off, & take a look. Stop driving it if your breaks might be leaking.
Old Jun 15, 2009 | 06:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
i thought maybe brake fluid but my brakes still stop fine...
Welcome to TGO. Check the fluid level in the master. Check the line to the brake (does the car pull to one side when you brake?). Check the fitting to caliper.
JamesC
Old Jun 15, 2009 | 06:54 AM
the car does seem to pull to the right but not all the time and the fluid levels seem ok
Old Jun 15, 2009 | 07:04 AM
JamesC's Avatar
That would mean the left hose is, perhaps, acting as a check valve. Is that the side the leak is on?
JamesC
Old Jun 15, 2009 | 07:06 AM
no its on the passenger side
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
jklein337
Sep 19, 2018 06:23 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
