6x9 install
Old Apr 27, 2002 | 04:27 PM
racer101's Avatar
6x9 install
how do you install 6x9's in the sail panel? i have an 87 iroc and
my stock speakers were in the kick panels and the hatch lid.
racer
Old Apr 27, 2002 | 07:23 PM
Shagwell's Avatar
Car: projects.......
I would have to say that somebody has already done some rearranging in your car. The factory speakers in all hardtop/t-top 3rd gens are 4x6 dash speakers, and 6x9 in the sail panels. - anyhow, pull the screw out of the close hanger hook on the rear side panels and pull up on them. This will unhook them and the holes for 6x9's should be there.
Old Apr 27, 2002 | 07:57 PM
racer101's Avatar
it came stock with the speakers in the trunk and kick panel.
when i take the hanger off and pull out the piece that it holds on, there is a solid piece of plastic, and behind it is solid sheet metal, no mounting holes or anything. do they sell some sort of mounting bracket?
Old Apr 27, 2002 | 09:19 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
My '87 Formula had a plastic enclosure with two speakers in it. This enclosure went into, and down a rectangular hole behind the sail panel. The hole wasn't large enough for a 6x9 so I had to cut away some sheet metal and mount them on a piece of fiberboard. I posted about this setup and no one responed that they had seen it before. Now we have one with NO hole in the sheetmetal! Has anyone else seen one of these two setups?
Old Apr 28, 2002 | 12:13 AM
racer101's Avatar
i have never heard of these methods before but i would be grateful if you posted the one where you don't cut the sheet metal.
Old Apr 29, 2002 | 01:14 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
No kidding... what kind of stock sound system was that??? Some kind of funky option? I can't see why GM would cut those 6x9 holes in a million Firebirds, and leave a couple hundred un-cut. Is that the real car body metal back there, or is it a plate covering up a hole?
Old Apr 29, 2002 | 03:25 PM
86IROCZ's Avatar
Re: 6x9 install
racer
Sounds to me like your car came equipped with the factory BOSE system. They don't have sail panel speakers.
When I puled the Bose kick panel speakers out of the the donor car I really didn't pay much attention to the sail panels since I already knew there were no speakers there.
There should be a hole ( a big square one) that an adapter plate that holds the 6X9 goes into. I'm not really sure though.
edit: Oh yeah, they don't have the dash speakers either.
Old Apr 29, 2002 | 05:48 PM
racer101's Avatar
you are correct 86irocz
there is an indentation in the sheetmetal but no holes to screw anything in to.
Old Apr 29, 2002 | 10:23 PM
racer101's Avatar
i am an idiot
i had just felt for holes in the sheetmetal, when i actually cut away the plastic there were holes for the speakers, just like everyone said.
they don't match the speakers at all but they are there. do they make a bracket to mount them or do i have to rig something so they fit?
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
zayne0
Aug 24, 2015 07:22 PM
