Is it possible to bridge a 4 channel amp to 1 channel?
Old Apr 30, 2002 | 09:33 PM
383 Smoka's Avatar
I was looking around in my basement and I have a little system that I forgot about... My buddy has a Geo Metro and wants a small system.. So I hooked it up for him... I bridged the 2 left channels to 1 and now I have nothing on the right 2 channels.. Its a little pyramid 300 watt crappy amp but right now im only using half the amps power.. Its hooked up to one little 10 inch pyramid 300 watt sub... It barely bumps right now.. But an extra 100 watts or so could prolly make it move a bit better... Anyone know how? Its a single voice coil ****ty sub...
Old Apr 30, 2002 | 09:36 PM
383 Smoka's Avatar
Whut if I bridged channels 1+2 and connected the wires into the positive input on the sub, and bridged channels 3+4 into the negative input of the sub? Whut would this do?
Old Apr 30, 2002 | 09:46 PM
pimpinthaz28's Avatar
Your amp would get really hot, really quick and u would prolly burn up the fuse and possibably the power wire. If the sub was DVC then u could do it but unless im mistaken u cant sefely hook it up like that.
Old May 1, 2002 | 01:10 AM
nagga's Avatar
they way you bridged it is wrong, u have to bridge the left and right channels, so u have to bridge front channels with front, and rear channels with rear, that way help alot, try it and see
Old May 1, 2002 | 12:53 PM
I know but can u bridge a 4 channel amp to one speaker?? how would u do that?
Old May 1, 2002 | 02:57 PM
Makaveli's Avatar
if it was a DVC speaker, birdge 2 channels and hook it up to one voice coil, and bridge the other two channels and hook it to the other voice coil. pretty sure...
Old May 1, 2002 | 03:13 PM
mcss383's Avatar
No you can't bridge the 4 channels all down to one.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
