Will this box work
Old May 8, 2002 | 08:53 PM
iroc_cragg's Avatar
Will this box work
Hey
I am making a custom box for my 2 10" rockford subs. The box is built to spec with the right air volume needed. There is only one thing that might be wrong with it. The subs are 10" and the top of the box is 10 1/4". The holes only need to be cut out to 9 1/4". Will the subs fit in fine or do u think that I will run into problems.
Old May 8, 2002 | 09:59 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
sounds like it'll be fine. It shouldn't be hard to tell just by looking. Do you have room to mount it or not?
Old May 8, 2002 | 11:17 PM
iroc_cragg's Avatar
Yes there is enough room to mount iy but there will only be 1/4" extra on each side after is been mounted.
Old May 8, 2002 | 11:57 PM
caleb's Avatar
Car: 89' Iroc
actually it would be an 1/8 of an inch on each side, because the sub is 10, and the box is 10 1/4 only leaving you with a 1/4 inch divided by 2 gives you 1/8 each side
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
backtothe80s
Sep 5, 2015 12:39 AM
Street Lethal
Aug 13, 2015 08:28 PM
marcusaw
Aug 10, 2015 08:13 AM
